2G 2G ECMLink speed density setup help
dsmjunkie97
36
May 22, 2008
Reading, Pennsylvania
Hey guys, i am hoping to get some help getting my 2g up and running with speed density. I have ecmlink v3 full with an aem 3.5bar map sensor. I currently have the ecmlink running on speed density but it idles pig rich in the 12.0 range. I could use some tips on seting up a base speed density map. I also do not have my ait currently installed yet which i am working on. I was able to drive around the block but any amount of throttle i was in the low 11.0 range on the wideband. I also am running only a wideband without a factory o2 sensor. The wideband is wired into the ecm input as instructed. The whole engine is a new build so any info would be greatly appreciated from anyone experienced with this.
Yes i can put the intake tube back on with factory 2g mas. I was reading up and that was suggested. It looks like i have to switch the ecmlink back the 2g maf setup and do some logging? Also i never setup a mas before, i know there sometimes is smoothing to be done. Once i dial in the 2g mas what is the process to setting up the speed density table using the 2g mas information?
