420A SPA Turbo fuel management unit rich idle
jesse12345
1,269
1,122
Jul 30, 2014
Minnesota
Hey all so I'm using the SPA Turbo fuel management unit, I think max is 14:1 on it and it works great, I'm running real rich at idle and my fuel pressure at idle is around 29 lbs. Have any of you tried that unit out yet? I know I need to pick up a megasquirt but I'm running low boost for now just trying to enjoy the car. I have a new front and rear o2 sensor on the way, my front one is new already but I'll just snag another new one just to make sure.
Internally stock I'm guessing? Also could you drop a link for the specific unit you're talking about? SPA makes a few different ones.
Ik this is an old thread but I’d still like to chime in for someone in the future to read this… the fmu I got from spa turbo would only let me drop my base pressure to about 30psi, what I discovered is that you need to take it apart and sand down the plunger until you’re happy with it. Basically it gets rid of a lot of spring pre load and now I’m able to go all the way down to 5psi
