420A 420a Engine Management
Street 2G
76
Jan 5, 2008
pasadena, Maryland
Ok I've been searching around for a while now and I'm looking for engine management for the 420a Eclipse, I'm trying to take all the scattered info and put it into one thread. I want to take this from fuel management, to piggy backs, data loggers, and even full engine management. Lets also get a little description of each if you can. so, what can be used,
There is an entire section dedicated to ENGINE MANAGEMENT for the 420a. Being new I dont know if you can see it or not but I would think you can even if youre suppose to just post in the BOLT-ON section for being new.
Anyway, it would have everything you would need to know regarding engine management being that that is the title of the section to begin with :thumb:
420A Engine Management - DSM Forums
can i use 98 gst 550 injectors on my 98 gs 420a
Injectors for the turbocars can be used, but you will need the turbocar resistor pack, some method of fuel management in place, and an actual need for larger-than-stock injectors.
:beatentodeath:
Well I Have A T3-t4 Turbo But I Dont Know ### Injectors I Need And Fmu Were Can I Gett A Fmu For Cheap Money
