90AWDTalon
- 877
- 3
- Jan 5, 2003
Everett,
Washington
I went drag racing Friday, every run something was slipping. It happened twice in second, twice in third, and once in both second and fourth. Every time it happened at gear change. I would shift gear as soon as I was back on the throttle it went straight to the rev limiter, I let up and hit the throttle hard again and had full grip. I was running on 225/40/18 azenis rt-615, I have a horsepower freaks cintered bronze clutch with an act 2600 pp, and I still have the 175,000 mile original center lsd. I've been running this setup all year and haven't had a hint of slippage prior to Friday.
I've got three theories:
1) Wheel spin - Other people were complaining about the track being greasy, but I dought this was what was happening since the 4th gear slip would have been at 100 mph.
2) Clutch slippage - This clutch is suppossed to hold over 700whp, I've only made about 35-40 drag launches on it and 2500 street miles tops. There was no burnt clutch smell, but does a cintered bronze clutch stink when it slips? And with just a quick on off on the gas I had no slippage any more. Every other experience I've had with a slipping clutch the grip didn't return instantly, it was gradual.
3)Center LSD - This is the original 175,000 mile unit, it has been abused for the 3.5 years and 35,000 miles I've had the car. Also driving home after breaking my rear diff a couple months ago wasn't good for it. I'm theorizing that the lsd was reacting slowly, it wasn't locking the front and rear together causing one set up wheels to spin then by the time I let off and got back on it the viscous goo was heated up and locking the front and rear together.
Here's a link to the thread I started in the track section of this forum. I have some logs showing the slippage posted there.
http://www.dsmtuners.com/forums/showthread.php?t=241283
Anyone have any thoughts or idea's?
