spyderdrifter
- 5,426
- 860
- Jul 11, 2009
Somewhere in,
Colorado
So after stressing over my smoking issue, I finally got a leak down test done last night. All cylinders were pressurized to 95psi @ TDC on compression stroke. No leaks in any cylinder what so ever. I followed this with yet another compression test which resulted in 125psi, also on every cylinder. For those of you who haven't followed progress with my Spyder, I replaced the piston rings and all corresponding bearings, bolts, seals, and gaskets related to pulling the engine apart for the ring job only 2000 miles ago. I did a proper "balls to the wall" break-in to seal the rings. My car still smokes and it usually looks white, but there's potential for it to be a very faint blue as there's a burnt oil smell to it and I'm not leaking coolant at all. I'm not leaking oil anywhere either. My turbo seals being bad has been suggested by a couple people, however, I'm inclined not to believe my turbo is the culprit for whatever is going on. It got rebuilt this year by Justin and has been nothing but awesome since putting it back in the car.
So I guess if there's a question here to be asked, it would be what could possibly be causing my smoking? The valve seals were replaced over this summer, the guides were replaced last summer along with a valve job. I've installed a filter on the vent line from the valve cover to the intake pipe, and I've checked the PCV system, which the valve too is fairly new. It's not OEM and came from Advance Auto (unfortunately), but it works properly. I'm at the end of ideas so I need some fresh ones.
), 125-130psi is normal for a rebuild at 6300ft? Not doubting you, but just doesn't seem right when it should be in the 178psi range.
