smoke!!
gabriel_dsm
73
Mar 27, 2014
bakersfield, California
Okay i jus changed my altenator on my car because my car was losing power! now there was left over oil around the bottom so i knew i was going to have a bit of smoke because its burning but this smoke is coming out of my exhaust alot of it but only when im launching than it stops. what does it mean?
watch the video to see what im talking about
video:
update: i just remembered we tried changing the oil however the filter i got was to small so we didnt but oil spilled everywhere could the oil filter be overflowing?
and no no codes show up and on start up it idels to 2k than drops down to 1
I'm not sure what causes it to idle so low, but mine does the same thing. I have to keep a foot on the gas keeping it at 1500 or higher for it to not smoke. I'm trying to find the problem. When I do, I'll let you know.
That's white smoke coming out the exhaust. Coolant burning, not oil. I would suspect a headgasket failure letting coolant into the combustion chamber. Don't know why it only does it on launch though.
Its the turbo check for play thats how mine was when it went. it would be fine when i first started going doing normal driving, if i made boost then after i got out of boost came the smoke show! then i would stop and a ton of smoke then would clear i would go again and nothing again. then it got so bad it always smoked then i replaced the turbo problem solved!
Ethanol is hygroscopic and miscible meaning it both absorbs water and mixes well with it. That kinda looks like water and if it's not your h/g you can check the fiav if you haven't removed it. Is the coolant low at all, im thinking (hoping) it's water in the gas.
As I said, if I keep the rpms up on mine, it doesn't smoke. Not sure if it's a head gasket. It may be running lean on low idles.
I wonder if your problem has to do with the difference between coolant jacket pressure and cylinder pressure at idle vs 1500+ RPM. By that I mean maybe at idle the cylinder pressure is low enough that the coolant can enter the combustion chamber and burn as white smoke. Above 1500 RPM the cylinder pressure is high enough to keep the coolant out. Does that make sense? I would do a coolant pressure test to try to rule out a blown head gasket.
Well if my theory that coolant is only getting into the combustion chamber at low cylinder pressure is correct this also explains the low idle. Car is choking on coolant in one or more cylinders at idle. I understand the blue smoke from a blown turbo (been there done that) but if we're dealing with white smoke we have a coolant issue, not oil.
Well, that may help us both solve our problem. I've got to tear mine apart and rebuild it, anyway. Guess I'll take care of pressure tests while I'm at it. Thanks. I'll check the turbo, too. Just in case.
Just be sure to do your coolant pressure tests BEFORE you drain coolant, pull the motor etc. or you will lose the opportunity to properly diagnose the problem. I'm pretty sure AutoZone or Advanced have coolant pressure testers in their "Lend a tool" program.
A blown turbo will be obvious once you have it off. Shaft play and oily residue are bad signs
