TurboDSM90
Freelancer
- 1,192
- 50
- Aug 20, 2002
Fremont, California,
California
Yes, I am plastering this all over the big forums. Its big news!!!
Mike over at Sinister Speed is onto something.
He is producing an 8" converter that will hopefully help us 1G auto guys out.
I believe there is less than a handful of DSMrs out there with this converter, but so far it has been promising testing it out just on the motor...on jackstands.
It crept up to 4200 rpms before pulling through the brakes. This is all off the bottle, no charge pipes hooked up, on the motor (no boost).
I got everything nice and hot, played with it for a bit off idle and such. I made sure the trans temp gauge was reading and got the trans fluid up to around 125*.
After messing with it for a bit in the log that I attached, I got the trans temps up to about 140*. So I would say yes it produces heat, but thats to be expected.
I set the MSD 2 step up to about 5000rpms just to see what the converter could give me until it pushed through the brakes. The highest I got out of it was 4200 rpms, the other two times it hit 4000rpms until it pushed through the brakes. Still on the motor, without the charge pipes hooked up. The motor will be 2 years old in April. Same rings, lots of blowby, about 130 compression across all 4 cylinders. As soon as the 2.1 is done, this one will go through a freshen up.
Here is a screen shot for those of you without V3 or that dont want to download the log.
I hope the 4202 can spool up decently without the nitrous..ok ok, maybe thats asking for too much
