- Thread starter
- #51
TurboDSM90
Freelancer
- 1,192
- 50
- Aug 20, 2002
Fremont, California,
California
ive been reading on stalls alot of people are getting and some people arent able to get much boost stalling.. my car is apart at the moment, but, when i drove it i could stall my 16g to 20 psi almost instantly.. rpm would rise to about 3800~ max.. there was no hesitation in the boost gauge just straight up..
i switched to an hx-35 and some cams and i can STILL spool it to 20 psi, and slowly rise to 3800~, not as fast but within 3 seconds..
my motor has 180k, cylinder pressure is 120-130..(wore out), and the trans was stock... and if i pumped brakes up good and held e brake right i could hold it all day long.. my car i did this on was a 95 gst...so was that a fluke that i had no problem stalling??
I would say its a combination of worn out internals in the converter and the trans, plus proper tuning (maybe even stock?). I had an automatic parts car that I could stall up to 4000rpms on the stock 13g turbo. Took me about 4-5 seconds, but it did it. I put my link on it, 1600s, speed density and wired the wastegate shut. It ran 14.4s and cut 1.8 60fts all day long through the stock exhaust and everything else except the mods mentioned. It could only squeeze out a spike of 22psi and dropped rapidly down to 14.
Just an FYI. I personally am going to hold off on getting everyone chubbed up for this converter and will most likely keep my testing results private for the most part. That is until everything is ironed out and perfected with the converter, and my setup. Too many haters at the moment when this thing is just getting started and people are already knocking it, even though its in its testing phase.
