Should this be happening?
Cool Mr Steve
553
11
Jul 18, 2004
Spanaway, Washington
Ok, at any boost level above 9-10 psi, lets say for example 15 psi, my car hits 15-16 psi then wavers a bit and usually, not always but usually, falls lower and stays at a constant lower boost. I can be boosting at a full 15 psi most of the way through second, but when I hit third my boost rise to 15 then fall and remain at 12. :mad: This makes me sad :mad: Should this be happening, or is it a boost leak? (Which, btw, I have 2 boost leaks at the throttle body that ARE IN THE PROCESS of being fixed. I don't want 15 replies telling me to do a boost leak test, just some incentive to repair what I've found) :cool:
2 things...
1. Vacuum hoses attached to MBC are too long causing boost spike.
2. MBC internals need to be replaced or the whole unit.
^Just like he said.
If you are running the stock turbo (t25) the only fix is to get something larger. It cannot hold 15-16 lbs of boost to 7000 rpm.
-T
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
