should i be able to see my flywheel?
Royalty
904
Apr 30, 2004
norfolk, Virginia
this is new to me but i was under tha car and saw this
WTF?!! is this a normal thing?
theres a seconday gasket piece that goes there, like from the bellhousing gasket, except it bolts on to the bottom of the blocka nd the bellhousing :thumb:
ok cool. then i should find and install this piece before tuening her over or would it be cool to run it like htis?
There's a small aluminum piece that fits over that gap. I can post a picture of it tomorrow if you need to see what it looks like. It's probably not that great of an idea to drive around like that because who knows what might get in there. Also, it looks like you're missing a bolt on your oil pan.
yea please attach or email me a pic. i need to find that thing.
heres a pic, the oil pan and TC are off here but its the flat metal
ok i now have a idea what it lookks like. if i cant find it could i get one off a N/T?
we have plenty of them junked around here.
I had the same problem. $6 for the part at dodge (said I had a laser). I believe it is caled a "lower bell housing cover," this is what thier compuer called it. And no, one off of an NT wouldn't work, if they even have anything similar.
If you're good with your hands you could make one out of some sheet metal. Just get a piece, trace the outline, cut it, drill holes for the bolts, and Bob's your uncle, a cover for your flywheel.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
