Shifting to Neutral causing car to shut off
DSMnOOb00
903
4
Apr 29, 2006
FRESNO, California
I'm having this idel issue with my car, I just had the engine rebuilt and it runs like a great. It's only when I come to a stop, I let off the throttle, put the car in neutral, when the car's RPMs will drop fast and car dies..
3
when I start the car, its idels good, and when im shifting from gear to gear it shifts okay... its only when going from gear to neutral.
I'm thinking maybe that I dont have enough air restriction? since everything I ported or larger then stock?
my upgrades in my profile are upto date
here are a few of the upgrades in my car
Bolt-on Modifications:
Stock Rebuilt 4G63 7 Bolt
MHI 16g turbo (PORTED)
Injen intake 4" Air filter & MAFT adapter
Dejon Tool Upper & Lower hard piping
Slow Boy Evo3 Exhaust Manifold
Greddy Type-RS BOV
o2 Housing (PORTED)
3' Apexi exhaust system
3' Magna Hi-flow cat (cali legal)
1G 60mm Throttle Body with Port-match intake-Manifold
Walbro 190lp Fuel Pump
Nope, took the chance to make a junkyard run for a bunch of misc. parts I need, then couldn't find my bike pump til it was dark (I'm working in a carport right now :ohdamn: ) So I'm definitely doing it first thing in the morning.. I'm hoping it's just a loose/cracked vac hose, I need an easy fix haha.
Do yourself a favor and forget that bike pump. You're going to want to source a compressor or at the very least a portable air tank. A bike pump cannot output the volume of air needed for a BLT, you'll pump forever and just tire your arms out.
Should always boost leak test your car to at least 20 psi. Room for stock cars to boost spike & etc.
I would check your timing. This can definitively cause a car to stall out when no load is on motor.
