Seen this alot but no real answer!!!
jonbusa
34
Oct 27, 2010
London, Arkansas
Ok let me say this please do not chime in on this unless u have tried it or have done it. I dont want any kinda a fuss or hearsay if u havnt done it dont voice ## opinion
Ok here it is.... I have a 96 gst and im puttn evo9 internals the guy i got the crank from pretty much just gave me a set of EVO 8 NON mivec cams....
Will they work in a stock 2g head???
What do i have to do
Are you just using the crank or did you get other parts too? In my last GSX build I used the pistons from an evo8
I've used everything except the crank thats on your list and it ran amazingly. So yes to all of that. I did some research and it showed that the crank should work also.
His post indicates he already knows the crank, pistons, and rods will work (which they all will). He is asking of the cam will work.
And in the final words of the post you so kindly quoted I stated that on my other forum there is a guy running the cams (aka research). Pay attention my friend. And nowhere does the OP state he knew that the internals would work.:notgood:
the op needs to reword his post making it hard for us to reply not knowing exactly what hes talking about which sounds like he asking if the evo cams will work in his head
You didn't say anything about cams. The OP asked if THEY will work in a 2g head. Last time I checked, pistons and rods don't go in the head.
He never asked if the pistons and rods and crank will work. He only asked if the cams will work.
I did pay attention, that's how I know what the OP is asking.
You didn't say anything about cams. The OP asked if THEY will work in a 2g head. Last time I checked, pistons ams rods don't go in the head.
HAHAHA. Just noticed that I put the completly wrong word. I meant crank not cams. Stupid me. Sorry for going at you. Its just me. A
anyways, yes, your fine OP
Yes i want to know if the CAMS From and EVO 8 non mivec will work n a 2g head???
Direct bolt on?
Ok so they are not a direct in thanks for the info
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
