searched but no answer someone help plz
dope96clipse
137
Oct 8, 2003
N.P., California
ok heres the problem, i am putting new springs on my car, i have done the rear (no problems) now im doin the front an i took everythng off, upper control arm, sway link, lower A arm an so one to clean them from an oil leak i had well i am putting it all together an my last 2 steps are the upper control arm ball joint and the brake disc/caliper. well the brakes r easy but the ball joint is a bi***, im tryin to screw the nut on the ball joint but the joint bolt just spins what can i do to keep it in place while i screw the nut on an torque it down???????? please some one help me ive been at it for 2 days an am getting really fustrated.
thanks for the patience, doug
ok thanks, that gave me a little info on how to get th ball joint in place so i can finish the drivers side thanks bro
  • Wanted 6 bolt NT water pipe
    • chrisman287
