Charcoal Canister Removal (searched , no answer)
MikeCordell
57
Apr 3, 2006
Barksdale AFB, Louisiana
Okay before I get the use the search answer, I did, not only that, I looked at every pic in the engine pic gallery. That out of the way, I removed my charcoal canister. There are 2 vacuum lines (that I know of) that go to this thing, I removed the associated splitters, etc. and now I am left with 2 open ports on my manifold. There are also 4 unused ones on the passenger side bottom of the intake manifold and 2 unused ones on the drivers side bottom. Do these need to be capped off? Should I only have 4 TOTAL of these small vacuum lines being used at the moment? Sorry if I am a bit slow but I do not learn well by reading, I learn by example and there just are not sufficient pictures and my TB looks different from most that I have seen. Do I remove the lines going to the purge control solenoid? Do I remove it altogether? If so what do I do with the wires?
just cap the vacuum lines.I know there is a thread here somewhere but I cant find it either...saw it about two weeks ago.
All of them? My car came in the condition you see in the pictures just alot messier, basically nothing was bolted down. So I have no clue what goes on all of these various vacuum lines on the intake manifold. I mean, I am baffled by the two on the drivers side that are not being used. I have no clue what they could possibly be for. The other two over there go to the purge control solenoid and the fuel pressure solenoid from what I can see. I am no doubt, lost. Could the 4 on each side on the bottom of the intake manifold simply be connected to each other on both sides? I guess its time to pull the intake manifold and find out what really is going on down there, I'm more of a visual learner anyawys.
I have a 92 laser at home...if want I can go home and look at it and walk you through it and pm between each other.Im like you and I have to have it in front of me and get my hands on it.
As soon as I have some parts in hand I'll probably take you up on that offer!! The link someone posted didn't work, thanks for the try though!
Mike
  • Wanted 6 bolt NT water pipe
    • chrisman287
