SD Setup Help
kevintoscano
Mar 30, 2016
Corona, New York
After rebulding my gvr4's head and re assembling everything back together, the SD setup seems to have gone, I have the omnipower 4 map sensor wired up properly but my log still confuses me, please help thanks
The throttle body stays at 21% for whatever reason, I'm going to replace it and try logging again, but apart from that do you see anything else that is off in my log? I'm fairly new to the ECMLink system, thanks
Shows here you have a wideband in the front O2 position but you are not simulating and therefore it is not cycling. Also need to lock Baro input. Ive made some changes to your log. Download it and when plugged in select save to ecu.
