sbiggi
- 584
- 65
- Jan 10, 2005
Elizabeth,
Colorado
I couldnt find any posts on installing a scatter shield.
So here it goes.....
Car is a 1990 AWD Turbo.
I had to remove the waterpipe inorder to get the shield into place.
Unblot the ground wire from the starter bolt, it bolts to the scatter shield now.
The shield goes under the starter wires.
So I got the shield on.
but it doesn't quite clear the water pipe.
Its hard to see but it is a 1/16th" away from the block as well as to high.
I'm not sure how I'm going to get it to fit.
I can either bend the small pipe to get it around the shield, but it might crack since its so close to the joint.
or
I'll redrill the mounting hole and then put a washer behind the mounting tab to take up the space.
Any suggestions?
-Seth
or
Any suggestions?
-Seth
