Runs rich, stuck in open loop
Dante923
Jul 29, 2012
Vineland, New Jersey
Hey, I recently got ecmlink v3 and I have 0 experience with it. I am trying to get the idle right in my car cause it surges and occasionally, when the car is warmed up, it will not stay on. Other times it surges and sometimes it stays steady but the o2 in the log stays steady.
I have a cel 0012, MAF code.I have a 3" gm maf wired straight to ecu with ecmlinks cable. I dont have a wideband :(, but I get horrible gas mileage, (around 10mpg so I know its running very rich. It runs so rich that if I shut the car off and turn the key into the on position right after, the engine will come back on). I have almost every symptom of idle surge from terrys guide, yes I read it so you dont have to tell me to.
My timing, Fuel pressure are ok. Im not 100% sure but I dont think I have any boost leaks or vacuum leaks (I checked all the vacuum lines and tightened all the piping).
Also, I have a blitz twin sbc and I cant control the boost very well with it. I maxed it out and it only goes to 15psi. A few months ago, I had the dial a little over half and it was at 20psi. I cant control the boost from link.
Overall, I believe my problems lies somewhere in the maf. I know my fuel tables arent that great but I gotta make sure this maf is functioning properly before I worry about that.
Below is a log from today, its a portion of a longer cruise (the last 3-5 minutes or so) The only thing that doesnt seem right is the MafRaw which stays steady arounf 24-25 no matter what the conditions are.
You might wanna check ## ecu ### I had the same problrm before but mines was ### I had upgraded injectors turbo and I was running the stock ecu and my car was not dyno tuned. Ecxactly the same problem
The words around ecu were ##ed out and i didnt see em, not sure what you mean. The ecu was checked out by ecmlink and its fine.
so it turns out the maf wasnt connected to the ecu (fml).... the problem is resolved now, just needs some tuning and it will be all set
  • For sale NEW Magnus Forged Transfercase gears
    Parts are new never used. Get some nice parts for a couple bucks off.If I don't replay right...
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
