shadow001dsm
- 183
- 0
- Mar 26, 2009
las vegas,
Nevada
I will get straight to the point i have a 94 gs that i have converted to the 4g63t will all stock internals, its has a stock 14b, 255lph pump. it starts up stong and idles good for about 30 sec then drops violently as if is going to stall but it stays on barely for about 6 revolutions after is bogs. but if you drive it and get the rpms up above 3 its build boost like normal but a @#$% ton of white smoke comes out, theres no coolant in the oil and no oil in the coolant. its looking oil on the drivers side( i thought it was the head gasket so i replaced it and still to no avail). any ideas on this? any help would be greatly appreiciated.
