sacrileger
- 303
- 48
- Jun 26, 2016
Orillia,
ON, Canada
I have some used valves (see pics) and am completely uncertain which can/not be re/used. Gentlemen, your esteemed opinion would be much appreciated.
Here are exhaust valves that were polished lightly with sand paper just to get carbon and other gunk off. The black rings are actually low spots that did not clean up (never mind the broken valve):
here's a close-up of valves that actually have dents in them
these are intake valves that were not touched (polished). The silver ring is actually worn in:
here is a close-up of the same intake valves to zoom-in on some of the imperfections and worn in ring:
Here's a different set of exhaust valves with similar microscopic low spots in the black ring as well as some surface deposits that did not clean-up
and here's a close-up on the exhaust valves above for better view and illustration
thank you
thank you
