95talon_in_ma
- 211
- 8
- Jun 29, 2006
Indian Orchard,
Massachusetts
I originally posted this in the Newb section, but haven't really gotten anywhere with it.
Car has no mods cept for an intake pipe and exhaust.
I was not working on it or changing anything when this happened.
I left one morning, did some errands parked it in the driveway and when I went back out there the car would not run for more than a sec. If I pressed the gas pedal during that time, it backfired and spit.
The CEL was not on. It made no noises or etc to give any indicatiopn something was wrong.
I have checked the following:
Timing is dead on. All points line up.
Tested ignition coil and replaced it with with working one.
Verified fuel was reaching the engine.
Verified Spark was good.
Checked all connections and hoses were plugged in.
The CEL finally came on permanantly now.But I just ordered my pocketlogger three days before this happened, but it won't be in until this thursday. (Must of had some weird preminition)
I have an identical parts car cept it was an auto.
I am narrowed down to thinking it's the Cam or Crank sensor.
The car will not get over 1000 rpm's and it loads up the plugs.
If it let it run and don't touch the gas, it lasts about 2-3 secs and dies.
If I hit the gas it pops volently and dies.
It sounds like timing, but again I verified that to the point bringing the piston to tdc and making sure the engine was on compression stroke and all timing marks lined up.
Can anyone tell me if they experienced something similar with any kind of sensor going bad? Will the car even run if one of those are bad?
Thanx in advance, Duane
