running really rich
larsenracing
554
13
Jun 16, 2005
Sioux Falls, South Dakota
I need help, My Talon is running really rich. It's a 96' esi, all it has done to it is CAI, welded on can, no cat, header, wires, new plugs, new coolant temp sensor and im pritty sure the 1st o2 sensor is good. I'm probably missing stuff but give me some advice I only get about 18mpg and after idleing for a few minuets it suts out the exhaust. help me out thanks.
larsenracing said:
It is for my 96 esi not my 97 GS-T. Everything is listed in the first form.
Whoops. Let's try this then:
1. Bring the car to an Autozone or scan it for codes.
2. If no codes come up, pull the O2 and have a look at it. If it's blackened, replace it.
3. While you're at it, check the second O2 sensor as well.
Give that a try,
Andy
you can get the code readings by turning the key on and off i was gonna send a link but the site was down all the codes are listed on neontuners.com
I have tryed that but i cant flash the codes out by turning the key on and off 3 times for somereason it wont do it but i will scan it again to check i also believe that the service light is out but anyway as andy said i will chech both o2 sensors to but im pretty sure that the front one is good but we will check. thanks guys for the help.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
