DSM Link Aquired (Running REALLY rich)
Chrispy0530
913
26
Aug 7, 2008
Miami, Florida
Okay, I tried posting in the tuners section but it didn't allow me. I just got my ECU back from ECMlink Inc, installed it. Connects with laptop no problem.
The big problem is that the car is running HORRIBLY RICH. Straight 10 on my wideband and bogs upon idle and any kind of acceleration.
Guess I should post a log?
My mods, and specifications I mentioned to ECMtuning,
450cc Injectors
16G Turbo
FMIC
190LPH Fuel Pump
Factory 2G MAS/MAF
Any help/idea's? I'm completely new to tuning and would like to get involved with it.
Log is below
Factory 2G MAS/MAF
If it's a factory MAF, I would start by zero'ing out the MAF compensation sliders. They are currently configured for a hacked 2G MAF, which is raising the airflow reading seen by the ECU substantially.
EDIT: If you're not sure where to do that, go into ECU Config->MAF Comp and then right click on the chart area and select "zero" then hit Save to ECU.
Thomas Dorris
Okay, sorry if I seem slow at this.
By "Zero-ing out", is this what you mean?
No, definitely not. That would be "70'ing it out" or something! You want all those values to be 0, not 70... Right click on the chart area and select "zero" then hit Save to ECU. All those values in the adj % column of the table should read 0% when you're done, not 70%.
Thomas Dorris
