Running hot/overheat at idle, fans working fine.
PurpleHazel
118
May 21, 2011
St. Louis-ish, Illinois
I'm looking for some input to be sure I'm on the right track here.
95 Talon 2.0 turbo, stock. Running hot (wouldn't take long to straight up overheat) while at idle for more than just 3 or 4 minutes. With or without ac on and both fans are working. New tstat & water pump within the last 3k.
I just got it a few months ago, and it has had water pump, timing, tstat, belts, fuel injectors, fuel pump, gas tank & pressure regulator all within the last 3k miles. Ac blasts ice cold and good heat. I have not yet flushed the coolant, and I'm thinking it needs to be done & probably just isn't cooling efficiently enough to cool at idle. Temp gauge is solid when moving. Turning heat on full blast keeps it in control in traffic.
It's been running beautifully for the last 2500 miles or so, but sat for a while with previous owner. The need for a flush probably the issue? Anything I'm missing here?
check your coolant level... as we use a pressurized system, it is possible it is low, or has air trapped in the system.. Also, as previously said, replace the inexpensive parts (T-stat, filler cap, coolant)
Cap and air bubbles were my issue with my last rebuild..
Best of Luck
A flush & new cap and once again, Hazel is happy. (No more hot flashes.)
Thanks so much for the reassurances. This is my first dsm, and a little intimidating when you've had 318s & 225s for the past 20 years or so. LOL.
Knock on wood, this ittle purple car runs DAMN good for a 16 yr old car with 100,000k+ .... she's a keeper. (Knock on wood onnnnnne more time.... ROFL )
