DOHCTA's Eclipse GSX
Mitsubishi Eclipse GSX
FP3582R Turbo, TiAL 44mm MVR WG vented, FP Mani ceramic black, FP mani blanket, Megan Racing 3" Turbo Back Exhaust, custom 4" FP cast intake and 9" K&N cone filter, custom 2.5" short route Yonaka type 10 fmic, TiAL Q BOV, AEM TruBoost Solenoid , Walboro 255HP, Fuelab hi-flow filter -6an braided lines, aeromotive a1000 afpr, PTE 880cc injectors. FP BB pre-filter, Jay Racing Saturn Alternator Relo Kit and Saturn alternator. Mishimoto 3 core rad and 2 12" fan shroud kit, Mishimoto Rad Cap with temp gauge and matching hoses, Frontline Fab -10an catch can Brightside coated and -10an welded valve cover. AEM Meth injection.
Mods-Engine
6bolt swap - 91 tsi engine, Micro polish crankshaft, Fluiddamper crank pulley, Ross Racing forged pistons, Eagle H-Beam Connecting Rods, Arp Main studs, Topline Oil Pump Assembly, Topline Waterpump, Topline complete gasket kit, Gates Timing belt, Mitsu Hydraulic Tensioner, Mitsu Idler and Tensioner pulleys, Felpro Perma-Torque MLS headgakset, ARP L19 Head studs, ACL Race Main Bearing set, ACL Race Rod Bearing set, Supertech valves & guides & valve steam seals, 3g lifters, HKS 272's cams, FP beehive springs & retainers, Fidanza cam gears, taylor 8mm red ign wires, ngk bpr7es, zaklee timing cover.
Mods-EMS & Logging
ECMLink V3, AEM gauges (TruBoost, water temp, oil psi, UEGO Wideband), Speed Density.
Mods-Drivetrain
Stage 4 (6-puck ceramic) Bully clutch kit, Fidanza V2 Flywheel. Megan Racing short shifter (50%) and RTM aluminium base shifter bushing kit, RTM Shifter cable bushings, Redline shockproof in tcase and lsd rear end. MT90 in stock 2gb awd transmission.
Megan Racing "EZ Streets" coilovers, RTM Spherical bearing top hats , complete prothane bushing kit, ingalls front and rear camber kit.
17x8 +40 Enkei GTC01 lightweight racing prototypes, 245/45/17 Hankook Ventus RS-3.
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
0.0 lb/ft
DOHCTA
More in 2G DSM
Share this Vehicle
