1G Rubber oil and coolant line replacement
And_44
835
8
Feb 13, 2010
Marysville, Washington
As title says I need to replace these lines. I replace the 14b with a 16g and in process of doing so found the stock coolant lines where so dry and brittle I want to replace them before installing the 16g. And while everything is out of way replace the lines going to and from the oil filter housing.
I know there are kits to upgrade to SS lines but I can do that later down the road. Right now I just want new rubber ones. Are they special hoses being so close to turbo or just radiator hose or fuel lines?
Thanks y'all for any response and of course your time.
Andrew
If it were me and I had the choice of running regular rubber vacuum hose or rubber fuel line hose for liquids, I would choose the rubber fuel line hose for liquids passing through it as fuel line hose is reinforced. Helps to prevent collapsing of the line and has a higher burst pressure.
