Rewiring a TPS???
Jonnynitrous
148
Nov 30, 2010
T bay, ON, Canada
I have a 90 talon and I picked up a min 90's TB(bigger). Would anyone know how to rewire the TPS or does the 90 tps bolt right up? I have no clue
Do you mean perhaps you bought a MID 90's TB? If so, Im not sure if the 90 TPS will bolt up, however, it will be very simple to determine this. Just unbolt each TPS and swap. If the bolt holes line up, and youre able to turn the TPS throughout its range of adjustment on the later model TB, youre good to go, however, you will also want to examine the design of the flange the TPS sits on, as well as the design of the shaft to confirm proper fitment and operation. If all looks well, you can mount the sensor on the new TB and plug the sensor into the car and have someone open and close the new tb by hand (You can do this with the new TB off the car, just mount and plug in the sensor) as you examine the TPS value on the logger to confirm its sitting at 10.5% at the closed position and 99+% at full open. You will first have to adjust the TPS to 10.5% closed on the logger and tighten the bolts before performing this test. Make sense??
Awesome thats what i was looking for! Thank you. One other thing, wiring the newer one up is it straight top wire to top wire and so on or is it color coded the same?
Yes perhaps I had purchaced a MID 90 TB. I can try to bolt it up and run through the steps.but i need to drive the car and not mess around. There are very intellegent people on this site that help out and I have paid back to the site by helping others.
1 question why would I be setting my tps to 10.5% when closed?
Regarding the TPS in closed position, you used to have to adjust the TPS by voltage, using a multimeter, the voltage of a properly adjusted TPS translates to 10.5% on the logger- MMCD, specifically. Just a lot quicker and easier way to set it is all.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
