starlord
- 0
- Dec 31, 2015
genoa,
Colorado
I have searched for days and weeks but nobody has had this problem. So I replace my heater core and i have never had so many issues in my life. the car ran wonderfully before the change. i had an srs issue but i have that bug worked out. Then i scanned it and the TPS was at 100% when closed so i echanged with the one off of a stealth it had all the same numbers and markings so its identical i imagine they are the same. but no change at all, tested the lead wires and i got all good voltage from the wires. so jumped to the idea of a bad ecu, so i swapped one i got off of ebay, even made sure it had the exact same numbers and markings. i tested the harness for wires grounded out.
Pins
1-#1 injector
4 Idle speed control motor coil A1
6 EGR
13 ground
14 #2 injector
17 ISC motor coil a2
19 Volume air flow sensor reset signal
24 unknown
26 ground
36 check engine light
72 Intake air temp sensor
81 sensorimpressed voltage
83 coolent temp sensor
87 closed throttle position swithc (idle switch)
90 volume air flow
92 sensor ground.
all of these pins were grounded in the harness.
I tested the for boost leaks also.
also i removed the ac and cruise when i did the evo3.RVR swap and it ran great before the heater core.
SO what could i have done inside the cab to mess this up?
I also pulled the dash 3 or four times to quadruple check that everything was put back as before. all i left out was the ac condenser unit (interior unit) and cruise control switch in the steering wheel. everything else is as it was before. any ideas?
PLEASE PLEASE HELP!!!
Pins
1-#1 injector
6 EGR
13 ground
14 #2 injector
24 unknown
26 ground
90 volume air flow
92 sensor ground.
