Reuse Torqued Head Gasket? (Composite)
BLOHS7844
300
Oct 25, 2011
Appleton, Wisconsin
I've read way too many different opinions on this to be sure. I torqued a new OEM Composite head gasket and its been sitting for a couple months now. It was idled for maybe 20-30 seconds at the most. Can I reuse it? If it matters, I plan to get my head resurfaced and I used copper spray.
It isn't recommended. That said, I have done exactly what you are describing and got away with it... Twice. If you don't mind having to put a new one in if your gamble fails, then do it. It is a matter of how much you mind doing the extra work if your luck runs out. When I did it, I sprayed that copper crap all over it and torqued it down about 5lbs tighter than it had been torqued the first time.
I would HIGHLY advise against it. If the head was recently milled, skip that and put the cash towards a Felpro gasket. I'd also recommend head studs if your using the stock 7-bolt head bolts. The stockers are almost to the point of stretching just torqued down.
But seriously, is the risk of blowing a head gasket worth saving $40? Reusing gaskets is as cheap as it gets. Stop by Oreillys and pick up a Felpro.
List: Search for 'head gasket' | O'Reilly Auto Parts
I might reuse it if a new one costs over $100+ but when the proven Felpros are in stock for less then 30-40$, I say the risk it too high and buy a new one.
You'll thank yourself later for doing it right the first time on a HG, trust me on that one :D
Is there any difference between felpro and oem?
OE (Original Equipment)- Parts/brands that were installed from the factory such as Mitsubishi, Denso, and Nippon. When it comes to DSM's these are typically the best parts to use.
OEM (Original Equipment Manufacturer)- Parts/brands meant to directly replace OE parts such as Felpro, Topline, and NGK. Quality OEM brands (like NGK) often meet or exceed OE quality.
Sorry, pet peeve of mine :)
But since Felpro is OEM, I'm assuming you mean Felpro vs OE Mitsubishi. Felpro is a reputable gasket company. Their head gaskets have been proven to be just as strong as the Mitsubishi gasket. I know of a DSMTalk member who made over 600hp on a Felpro gasket and ARP studs.
If I were you I would spend the extra money for a new one and not have to worry if it is going to fail some people believe oem is better than composite but others have proven felpro can take a beating
Just as a side note, both of the gaskets I reused were Felpro composites. I have a Felpro in my engine now also, and have used nothing but Felpros for many years.. The Felpro composite gasket is very forgiving and can stand a lot of abuse. We put Felpros into a 94 Supra pushing 900 hp and it took a hell of a beating for a couple years... Of all the crap that broke on that car, the headgasket wasn't one of them. They have always worked well for me.
I am not telling the person not to use a felpro I just would not reuse any gasket to save a couple dollars and want the extra insurance or peace of mind
Agreed, new is always better/safer/smarter. The 2 times I reused gaskets, the vehicles needed to be running immediately and I had no option of waiting for a new one before the head needed to be back on and ready to run. Not ideal circumstances, but like I said, the Felpro composite is very forgiving. I also have all of the tools, equipment, and previous experience to get the head off the block, change out the gasket, and put it back together in a few hours... So the risk in my case is only a minor inconvenience. I don't think that is the case for most folks, so in that instance the risk of severe pain in the ass if it fails far outweighs any savings from reuse.
