[RESOLVED] Stripped fuel rail hole on the head
sadc
274
Feb 17, 2008
Kapolei, Hawaii
So I stripped 3 holes on the head, to where the bolts go to hold the fuel rail down. Is there something I can make these holes stronger? I know I have to drill new holes. I upgraded my bolts to like 20 grade or something. The OEM ones broke like twigs. But now I think I might have to go back to that. So anything to make the holes withstand more torque?
Those small bolts is not the problem. All they do is hold the fuel rail on. They do not have to have a lot of pressure to do that. Remember, so bolts do not have to be cranked down so hard. As for what to do now, You will have to drill out the old bolts and may have to rethread the hole.
You broke your fuel rail bolts? Just so you know, torque on those are 12Nm or 8.7ft lbs. You could even use a little blue loctite on them. Now your best bet would be to get a heli coil kit. Its consists of a tap, stainless threads and an insert tool. Find one for a M8x1.25 bolt.(I believe thats the size) Drill the hole per company recommendation, tap it, insert the heli coil and then install your rail. Besure to block off any open holes such as the injector holes if you're doing this on the car. Vaccume the shavings up when you're done.
Just like others have said, drill out the old bolt, heli-coil and you're done. Next time, when the first bolt breaks it's probably not a good idea to keep cranking down the other two the same way you did the first... it will save you a lot of time and hassle.
I think I'd use the time-sert's if I was doing this repair.
I never quite understand why these get stripped out. I assume that by the time people graduate from working on lawn mowers they realize that aluminum is pretty soft and you should check the torque values before tightening something.
Were you missing the black spacers and got carried away?
What I don't understand is how you could strip all 3 of them. You'd think before you got to the other two you would think to yourself, "Hey I probably shouldn't tighten these two like I did the first one."
No way, I never did put my rail back on without it :)
It was already half striped from the last owner :(. Just that when I put the high grade bolts in the holes. It made them worse
higher grade bolts dont' hurt threads, over torqueing, cross threading or putting in the wrong thread ruins bolt holes.. Drill then heli-coil / time-sert
One thing i've seen cause more people to ruin aluminum holes and break bolts in using an air ratchet.... NEVER use an air ratchet on aluminum parts and never use it to do the final snugging.. use the to take out bolts or to run in long bolts but do all final tightening by hand with a torque wrench if you can't feel the proper pressure needed to hold a bolt of that size without ruining it. Inexperienced wrench turners do this all the time (notice i didn't say mechanic, as a real mechani knows how NOT to do this)
Not dogging on you, but to ruin all 3 and why on earth would you even need or use a grade 20 (grade i've enver heard of) for soething that simply holds down your injectors.... that's a bolt for flywheels, head and main bolts or maybe holding a bridge to the road.... 8 grade is still more than what's needed on most holes on a mitsu in the motor or chassis
Just to say it again, torque on those are 12Nm or 8.7ft lbs. this is straight from a 97 Talon shop manual. That is just past snug. Air ratchets put out more torque.
On the other hand, after you torque down the fuel rail, you should still be able to turn injectors left and right by hand.
And I think my experience with studs is the same as Steve said.
