1992awdlaser
- 3,051
- 26
- Dec 5, 2004
Wallace,
North_Carolina
Does anybody know how/if this piece can be removed from the transmission?
Note: This feature currently requires accessing the site using the built-in Safari browser.
With the cables unhook see how well the leavers on the tranny move. If they center themselve . IF so then i would replace the bearing and make sure the cables are free try lubing the cables make sure they are free.
Adjust your shifter cables Shifter Adjustment
1992awdlaser said:It's the position that the bearing is at on the shifter arm. It is not centered so it is pulling the end of the shifter cable toward the driver side of the car which makes the cable bind.
