[RESOLVED] Power windows go down when car is off???
That happens in my 98 Accord; the window switches have power for about a minute or two after turning the key to 'Off'. Doesn't happen on my DSM though.
Ya it does it on my 05' F150 to, but when I open the door it stops/shuts off. I opened the door,shut the door and locked it,opened it back up and it still did it. I am just worried it might drain my bat. Other than that it doesnt bother me.
I guess ill find out when I go back to work in a few min.
Josh
It's normal, but if it still happens after the delayed time the previous owner might have jumped the window relay keeping it always on.
i wouldn't be concerned with this draining the battery, as long as the car doesn't sit for an extended period of time.
as long as the window motor isn't running (switch activated) it won't draw current from the battery.
i wouldn't worry about it:thumb:
The power windows remain functional for 20-30 seconds after the key has been turned off and before you open a door. This is controlled by the ETACS; while I've never heard of one failing, most I have encountered have had very inaccurate timers.
The power may have also been jumped by a previous owner. There is a tech article here (I believe by luv2rallye) covering how to do it.
This condition is not normal if functional beyond a minute or so, or with the key off and the door open.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
