Resolved 420A Power windows
pdodson18
47
Apr 3, 2025
carrollton, Georgia
Hey I replaced both regulator and the motor on my windows and just recently bought switches for them. I know that both of the modules work and when I plugged it up windows don’t work.
I have a connector at the bottom of my driver side dash that isn’t connected and am also wondering what that is.
Fuses are good. I’m thinking it could be the connector or the relay.
Solution
I believe that is part of the OBD connection...."OBD 1.5".....what year is your car and did you just lose your window function? Or is anything else inop as well? I would check fuses first, then check the wiring at the flex joint between the door hinges. If you need wiring diagram information look on www.vfaq.com and you will find everything you could possibly need to know about these cars 👍🏻
@pdodson18
Since it sounds like you got your power windows issue figured out, would you please share with us what the solution was?
For me I replaced the relay and it worked 😀
Any suggestions or help???
I have a 97 eclipse rs. Everything works except both windows and the passenger door lock. I checked the engine bay fuse (30a) and it is good. I have both obd connections already mounted up it’s a black one and a yellow ish one. This one is just loose and no clue what it goes too. I’m going to look at that site and see what I can figure out. Thanks
I have a 97 Eclipse RS and everywhere online I’m seeing power windows fuse is #4 but on my fuse cover it says #10 is for power windows. The #4 spot doesn’t have the teeth for a fuse to go into it but I’m wondering if there is a way to try it since my power windows don’t go up and down.
Power windows fuse is #9 in the engine bay fuse box.
@pdodson18
Solution
