[RESOLVED] hard start when the car is cooled down
xreaction122
258
Oct 28, 2007
Albany, New York
i got a small problem i need to fix before winter hits. the falling leaves warn me that theres gonna be trouble ahead of me soonROFL.
i have to crank the car for about 10 seconds in order to start it and even when it does starts, i cant hit the throttle more then 20% or else the engine dies. it sounds like im getting multiple misfires when i start the car.now i thought it was the coolant temp sensor going and i checked and it was just fine since i was getting a reading from the gauge cluster
i have to sit there and let it warm up for about 10 mins. i properly gapped/replaced the plugs with NGK and tried new plug wires also. no known boost leaks either.
what could be my issue?
it starts up just fine when its warmed up...
any ideas??
My 1g done this but a little worse and mine was cause by my mass. I switched to the 2g mass and have not had a problem with it starting since.
any ideas??
The coolant temp sensor doesn't send the signal for the gauge cluster, there is a separate single wire for that. The ECT sends it's signal to the ECU, do you have a logger? If so see if you get a coolant temp reading from that. Also physically inspect the wiring on the ECT to make sure it hasn't got messed up.
ohh i think i know what your talking about. the small metal clip on the side of the housing.
im gonna have to double check on the coolant temp sensor.
check the two wire coolant temp sensor, use a ohm meter to check the resistance and make sure the wires have continuity all the way to the ecu
checked the coolant temp. sensor and rewired the harness.
ill keep an update if it still does it in the morning or not.
  • For sale 2g 2G 7 Bolt Lower Timing Cover
    2G 7 Bolt Lower Timing Cover $80 + shipping & paypal fees* there are a few flaws ( pictured )...
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
