[RESOLVED] no reverse after car is warm (5 speed)
canucatchdis
333
Jan 2, 2003
Moline, Illinois
Ok, I have searched because I could swear I read an article about this before but maybe not.
My reverse will work just fine when the car is cold (just started).
I cannot go into reverse after I have driven around a bit. The shifter will move into the spot where reverse should be but it acts as if nothing is there. I have looked under the hood to see if my intercooler piping was resting on the shift cables but that is not the case.
Any suggestions?
Well lets start with the easy stuff, have you checked the transmission fluid?
See if you can drain a bit of tranny fluid out and let us know what material appears to be most prevalent...aluminum, brass, steel, etc.
Synthethic fluid? What kind?
I have synthetic fluid in there currently. The fluid is Red Lines MTL. If it has any relation, I have Mobile 1 synthetic 75w 90 in the transfer case.
Could this possibly be a result of the bushings on the end of the shifter cables being warn out?
It could be the teeth are rounded off for rev gear causing engagement issues. Could be a broken shift cable. Could be bad bushings if it is not pushing the lever all the way forward to engage fully into rev. When cold the case is putting slightly tighter preloads on the input shaft, so it could be going into rev easier as the synchro for rev doesn't really have to work as hard. Once warmed up, the synchro needs more pressure in order to work and that needed added pressure might be just enough where the cable is unable to move the shift shaft far enough. I would definitely check cables, brackets, and bushings first...
Jack
Not sure why I thought the problem was only when the car was warm but I got it fixed.
The problem was the clip that holds the shift cable in place was missing. I found one and replaced it. I also did the ballbearing mod which is awsome.
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
