Replacing stock mounts
DSM1G90
5,096
75
Apr 6, 2008
Nampa, Idaho
Now, here's a question that I can't figure out: My Ply RS Turbo that has the front and back mounts are pretty well much done for-riding in the lower part of the rubber mounting area, but the rubber isn't all torn up.
Right side (transmission) mount is okey-sitting center. Got three mounts from a yard in excellent condition for 5 bucks apiece.
I put the jack with a 2x4 block of wood under the oilpan to lift up the motor. Got the left end (beltcover) mount changed out-it was pretty well tore up under the end covers.
Yet with the motor raised, the front and rear mount didn't show any sign of relieve when I raised the motor - just stayed in their respective positions.
Any clues on what is happening here?
Did this car do some pancaking and pushed up the center support causing the front mount (roll stopper...LOL) to raise some? But, that doesn't explain the rear mount being in the same condition.
Only recognizable underneath carriage damage is the two front bolts of the support all ratty from being scraped and one bolt was pushed over to where it bent some of that crossmember a little causing the AC condensor to buckle (which I took out since the system was all empty of freon..) whereas the beam itself looks pretty straight without any signs of buckling or scraping from a potiental pancake situation.
thx for the help - DSM
Try a second jack with a block of wood under the bellhousing. It's awkward because it's not flat but it will work if you place the wood along the edge next to the oil pan. Use both jacks to more evenly raise the engine. Remember that you don't have to raise the engine a lot, just enough to relieve the tension of the cross bolts of the mounts. Do only one mount at a time. No one engine position will work for all of the mounts. You will have to slightly reposition it for each mount using trial and error to find what works.
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
