Remove Antenna
aves911
100
Nov 13, 2002
Hey,
I am removing my antenna and don't particularly car to go through the hassle of shaving it. I saw once a 2G that had a park bench wing on it and where the old low rise wing used to mount up, they had used some little black plastic plugs to fill the holes.
Anybody know where to get these? I want to use it to cover the hole from the antenna.
Thanks,
-Jacob
I'd check the hardware store if you want plastic plugs, but my buddy just removed his WRX wing and cut some black duct tape circles that go over the hole. sounds jank but looks fine while he waits for his carbon fiber trunk . my $.02 -jam
Pop-in plugs like that should be available at PepBoys or the like. You may need to heat it and warp it a bit to fit the body, and silcone seal the back side of it. Just don't tell the parts dork that it's for the antenna, just say it's for a body plug, or the floor.
