redoing my 2g suspension
I havent gotten a chance to drive the car as it is completely under the knife right now. But I have fully installed the Prothane Full Suspension Kit and man what a PITA. Be prepared to spend a lot of time doing this upgrade if this is your choice. You will definitely need a press, and a few more bucks if some of your ball joints are shot as well. Cant wait till i get my car up and running. I also run the Tokico Illumina Shocks and Eibach Pro Springs. Had a few friends run this setup and they like it. Good luck!
If your going to be driving around the Chicagoland area, stick with an Eibach prokit or something equivalent with about a 1in or so drop. The potholes will kill you.
Koni Yellows with H&R Sport springs. If you can't afford to build a setup like Dg's
Prothane kit minus the bushing that goes in the lower control are where the dampener fork bolts.
I would not use the Energy suspension kit. It's hard to install and the top bushing in the rear knuckles is known to fail pretty quick.
Kevin
Kevin
I just got a set of tokico shocks pretty cheap. So I'm going to run those until I can afford to buy a nice set of coilovers.
I had the energy suspension but I needed some more bushings so I sent it back and am waiting for the prothanes to come.
