Moonlight GSX
- 670
- 144
- Nov 16, 2010
Hagerman,
Idaho
Anyone saved, keep 'em alive.
I removed the exhaust and took it to a shop, that had previously failed me with exhaust welding on another car.My exhaust separated itself from the turbo
Had to reverseback into drive way, shortest drive ever.
Decided to go back to the civic dual core half radiator I used earlier in the thread.
I had to because my slim fan failed and I decided I wanted another SPAL shrouded fan. And it only fits with a half rad.
I now have both the curves and straight versions of the 13” shrouded series.
The straight paddle is a lill shorter, so it fits better in front of the exhaust manifold.
View attachment 770841View attachment 770844View attachment 770845
The curves one (1860) cfm pulls around 13 amps
And the straight one (1680) cfm pulls around 10 amps well within the 30 amps allowed by the fuse box.
I went ahead and replaced the dryer, since some threadson here also mentioned that being a cause for excessive coolant temps when AC is on.
Once I refilled the system.View attachment 770846
I was able to get 55 F at the vents with very low rpm and the car never overheated or went past 195-200 with the AC running for about 30mns.
55 is good considering it was 95 F today and I have a massive intercooler in the way.
Haven’t had AC in this car in some time
It’s also so much hotter in FL this summer!
YesDo you cut out the trunk so you don't have to drop the subframe? Or how does this process work?
So I provided the item description in BOLDYou have a link or part number for them bushings?
Thanks, I recently finished my masters in Aerospace Engineering- my focus is “GNC”Excellent use of MATLAB, by the way what are you studying to be using such a program?
