- Thread starter
- #151
miliman13
- 2,489
- 689
- Jan 1, 2011
tampa,
Florida
DSM - K series shifter cable upgrade: 50$
As far as I know I'm the first to document and do this.
I took some measurements of the cable in the car as a starting reference when searching online.
https://www.dsmtuners.com/threads/d...-of-the-shifter-cables.548540/#post-153940722
I noticed my car would not want to shift and it was stiff at the shifter, but I recall my car use to shift very well, so I refused to believe the un-experienced who said, " bad trans bro ".
I disconnected the cables at shifter and at trans and began diagnosing each component of the system and concluded one shifter cable got damaged (while it sat for 7 years ?????), and I was able to confirm this as well when I would push or pull the shifter it felt like it "flexed".
So, I took a chance based on images alone, and I settled on this K series cables since they are supposed to be better than stock (the K series stock ones are only 30$) and they come with adjustable end links and a swivel for a good fitment, they are an EXACT fit to the 2G DSM... you don't have to modify anything. You don't need to use the clips, the provided collars work with our brackets, except for one in the interior, due to a bolt that gets in the way you can either remove bolt or use the retainer clip again.
It used to feel like I had bad gears but mostly a bad first gear, wow that issue is gone, I have not driven the car yet, all testing has been with car off.
I'm still testing it and believe I will need a shortm6x1.00 (1/4-28) male to female extension to get the placement perfectly, what I mean is these shifters feel like they have a shorter throw, so fine tuning the positions are needed to get a solid engagement from (1st gear all the way to reverse) since depending on where you adjust the end links you can feel resistance either moving shifter left or right making either 1&2 a Lill resistant or 5th and reverse.
One remedy to this is using the OEM shifter responsible for the left and right motion; the OEM shifter cables rubber gromet allow for you to remove the old, damaged shifter and replace it with another, leaving you with one OEM and one K series, this would resolve the forementioned issue about the left and right range being a little tight. I will be attempting both using the extension and the OEM cable once its driving for data collection and feedback.
