727DSM
- 0
- Jan 24, 2012
Tampa,
Florida
I want to know if this Spyder GST with a 4g64 is worth putting money into? I read i only has 141 HP and i dont see too many parts for it.
Also is the GST suspension different then the GS?
And if i turbo it will it be faster thn the 2.0DOHC?
get some forged internals, swap a 4g63 head on the block. Swap the wiring harness, get a 98/99 flashable ecu and call it a day. I actually have a 4g64 in my gst. Google the swap, its very easy. Plug a few holes on the deck of the block and you basically have a 4g63, everything is still the same but you have to use a 4g64 timing belt and 64 timing gears (or aftermarket).
