illeagle92
- 55
- 4
- Nov 1, 2013
Farmington,
New Hampshire
Hi guys! I've been doing some reading and through almost the entire build I've been able to answer my questions by searching... but this one not entirely.
My rebuilt 6 bolt is almost finished (stock bore + hone/polished crank/pressure tested oem head). Last few parts will be arriving tomorrow then if everything goes as planned it'll be going in along with the front mount, sd and fuel system.
The car will be fresh 6 bolt with a composite mitsu hg, arp studs, internally gated td05 20g, oem head with stock cams, 560cc injectors, walbro 255, pr fmic, and v3 with speed density. (There's more but the main stuff is listed).
I know the injectors aren't too much bigger than stock, but I'll have an FPR as well for good measure.
My question in... should I get it towed straight to the tuner and start it up/break it in on the dyno? Or will my stock ecu with a "blank(?)" dsmlink chip be able to get it started? I assume since there aren't any air/fuel numbers plugged in it won't know what to do. Is this correct?
Or can I have my tuner make me a basemap to break it in then get it there to get it tuned?
