Rebuilt engine
zachdeagle16
97
Nov 17, 2004
coosada, Alabama
I recently purchased a bootom end that has rebuilt before. Is there anything that i should look out for when I rebuild it this time. Also all of the journals on the crank mesaure to be in spec, but in the middle journal where the crank bearing goes, there is a little ridge on the left side that you can feel with your finger, is this a problem?
Use all new parts where ever you can, like a new oil pump and other stuff like that. Also if it stil has the balance shafts now is a good time to take those out to. I sent you a pm with some other info. hope that helps you out.
