Rear bumper removal?
remove the tails,centre piece and Plastic in the trunk,then undo all the bolts and nuts(some in rear wheel wells too:confused: ) and it should come off..,.:thumb:
Clean the area under ur rear bumper afterwards...itll be so messy
Its a little more in depth than that. There are in total about 30 bolts that you must remove to get your rear bumper off! I just did this over the weekend. Dont forget the ones inside the trunk panels where the corner of the bumper attaches to the back quarter panel (there are 2) And the two tabs under the bumper on the inside (hidden ) Good luck it took me about 2 hrs and a little cutting with a dremel. (the two hidden tabs)
good luck
