bumper removal
jonk00000
134
Nov 24, 2004
stormville, New York
I've done some searching but can't seem to find an obvious answer. This weekend I'm putting my front mount in. Before i go hacking unnessary bolts and such, what bolts besides the row under my bumper do i have to remove? Do i have to remove my headlights? any input much appreciated jon
YOu have to remove the plastic housings for the marker lights. Also gotta remove the turn signal corners. There will be maybe 8-10 12mm bolts holding the plastic to the bumper support. Go SLOW On these, as they WILL snap on you. MOst of the bottom bolts will snap off anyway. Gotta remove a LOT of the plastic ducting underneath as well. Don't forget about the 1 little bolt in each corner, right behind the side marker lights. Gotta pull 1 bolt and plastic fender shield away to get to them.
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
  • For sale 1g 1g BR upper intercooler pipe. Stainless Steel
    1g upper pipe. Early BR. 2.25 inch Stainless. Bead Rolled ends. BOV flange is gone...
  • For sale Anyone interested in brembo front brakes from a evo x?
    Hey guys I happened to come across evo x brembos that work great for a good price !
    • SheNeverRuns
