Rear brake caliper flexes when e-brake, then drags...
mhuffman
292
4
Nov 3, 2006
Bowie, Maryland
I have a 91 eclipse turbo built in oct 1990. My left rear caliper flexes when i pull up on the ebrake, and then the brakes start to drag heavily. They don't drag just using the footbrake, only after the caliper flexes from puling up on the ebrake. Has anyone had this problem?
At any rate, if i wanted to get new calipers, they specify that the calipers changed in 1/1991. Has anyone bolted on later 2/91+ rear calipers on a car built prior to 1/91?
turbs out my rear hardware was wrong.... ppl i bought the car from weren't so sharp. You can get the parts from autozone. All i needed was the caliper bolts.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
