Rear Axle
BkzProblem
214
Sep 7, 2008
Brooklyn, New York
I NEED HELP.... I need to find a right rear axle for my 95 awd lsd abs talon. I have been searching around for days and i have come up with nothing... I can only find front axles but no rear ones.. If anyone has the part number that i need, please let me know or just post up a link that i can go to.. Thank You.. If any vendors are reading this, you are welcome to let me know...
I dont have the part number but I got mine from pep boys about a year ago they didnt have it in stock but i had it in about 3 days i think.
im not trusting those stores anymore... They gave me the wrong axle that is too short and it ruined 2 of my differentials already... Thanks for your help but i need specific numbers now... I cant afford to keep replacing diffs...
No prob i hear you there that was just the only place around me that could get one. Have you tried calling the dealer to get the part number they should be able to pull it by the vin.
I'm in the same boat and I'm going to end up buying new from dsmgraveyard for $450 each. Dealer wanted $600 per side and you had to assemble them yourself. I called raxles and Marty said if you can pound it out of the hub and ship it too them, he'll rebuild for $160. But, he said don't torch them which I already had done so I was screwed there too.
Hope that helps.
Hope that helps.
damn that's expensive... i would send it out to get rebuilt if i had the right axles but for some reason these axles are too short and keeps pulling out of the diff... uhhh... Thanks for your help though....
Tell me about it.. I'm reswaping my gsx back to a awd. Bought the rear end from some kid only to find it a rusted piece of sh*t. Nearly 2k later and I'll be done:banghead:.
There are a pair of 95-99 lsd axles stuck in the hub on ebay. $200 obo then send to raxles - just a thought. I'm so tired of rust I'm just going to buy new.
Hope that helps.
Yeah i torched mine and f'ed them up big time. All i was trying to do was change the wheel bearing and ended up spending amost $600 on the wheel bearing and alxe sucked. I had to cut the axle in half to get it out so i could put the new parts in ha.
Damn... That sucks... These axles caused my first diff to go bad, then, i paid 315 for a brand new diff and now its starting to make noise again because of this stupid axle....
Ok so i went to pepboys, gb500 auto parts, strauss, and NO ONE carries a rear axle for this damn car.... UHHHHHH.... anyone else??
ok so now im reading that no one makes rebuildable rear axles for our cars.... can someone please clarify??
Ok.. THIS IS REDICULOUS..... if i cant find a rear axle within the next week, im selling the car. it makes no sense for me 2 keep a car when finding parts for it is nearly impossible.
JNZ Tuning Online- OEM Mitsubishi Parts
Go all the way to the bottom and find it for your application, wether you have abs or not, etc.
Hope this helps, don't want to see you get rid of your dsm.
THANKS... buth thats only for the shaft and the part that goes into the hub.. for the complete thing, including the inner piece that goes into the dff, its gonna cost almost $400... smh... THIS SUCKS!!!!!!!!!
Why can't you use your old axle cups?
