EagleTalonTim
- 830
- 13
- Jan 10, 2007
Brighton,
Tennessee
Finally, for the first time I get to take my car to the track. Before I left, I checked my timing and adjusted my boost controller to 10psi since my car does nothing but black smoke the entire time I am at WOT. I am running the stock 13b that comes on the auto's. The timing is at -7 BTDC. I am running NGKBPR63S plugs or something like that.. I know they are 6 something. They are less than one month old and so are the plug wires.
The track is one hour away, so I hit the interstate and set my cruise at 70. When I got to the track, I popped my hood to check everything again and my manifold and turbo was glowing! I just left it running and let it cool down. That is just one of my problems. When I finally got to go down the strip, I noticed that my boost gauge hit 20psi, then dropped right back down to 10psi where I set it. It only happens when I take off. Since my car is an Auto, the boost should stay the whole time down the track. I got one of my friends to watch me as I went down the track and they said it was black smoking the entire way down. Needless to say, me best run was a 16.1 at 86mph. My N/T was faster than that!!! What should I check for??? What is causing all my problems?
Thanks in advance!
Tim
Thanks in advance!
Tim
Wastegate spring pressure is 10psi, but you'll probably still pull harder on that 10 than you pull on 16 with the 13g now.
. Not arguing with TurboAnything but I would try fitting them up before I spent the BIG$$
I know for a fact that my temp gauge is not broken and that the temp sensor for the gauge is working correctly. What would cause this? Thanks again!
