1G Radiator Fans not working
dsmsucks
660
4
May 14, 2005
Rochester, New York
Okay the car is put up for the winter, so we all know what happens during this time
MORE PARTS:D I installed a slim fan and everything was working fine until. I went to to turn the ac switch on to see if the fan still works! The fan wouldnt come on. Before it would work and the fan would come on! So I took my test light and found out that I was only getting power to the low speed wire(Green w/ black strip) and no power to the high speed(blue with red strip)
Also the plug on the driverside fan isnt getting NO power! I dont want to just start ripping fuses out and replacing them because they cost well over 20 dollars a piece:mad:
any ideas
Fuses cost over $20 a peice? Man what are yours made of, platinum? Try hooking your old fans back up again and seeing if the work. If they don't then start tracing wire's and see where they go to. Test voltage at different spots along the way to see if you get voltage somewhere and maybe have an open. I would check fuses first though. Then check your relay for your fans by jumping it directly from the battery and giving it power.
    • Sdcryan1
