RayBan GST
- 665
- 4
- Oct 21, 2007
DUBAI UAE,
Asia
hi all i have searched and i have found only few posts talking about my problem
my fans (BOTH) kick in only when the temp level is above the temp signal on the stock 2g gauge
it just happen recently i dont know why ? before they used to kick in early , the tempreture now is MILLION DEGREES in dubai with 89% humidity and im afraid i will just destroy the car
once they kick in the temp will go back to normal and then again it will heat up until the fans kicks in
could it be my coolant sensor ? or the reading tempreture sensor on the thermostat housing reading wrong? how can i make sure ?
thanks for your help
i tried to adjust it , twist it but IN VAIN.
and thanks for your help
