2G Quick question about setting my timing
Tamatalon39
78
Aug 20, 2011
Robesonia, Pennsylvania
OK so I have another post about having a cyl with no c0mpression. Diagnosis was a burnt valve which i replace. upon redoing my belt timing (which I have never done on a DSM) It wont start so I check my compression again and it appears i dont have any. I lined up everything and rotated it over by hand several rotations. and nothing hit.
So my thing is I may have it off a tooth, if I do is it possible not to hit the pistons and also not build any compression?
I dont know if they are bent i had to go to work but i had it running and i pulled an injector to see if what sounded like a slight miss and after it stalled it wont start up. So i did another comp check and i am back to 0 again again it was running. Thinking i have a bad conp tester
Well anything is possible, make sure your doing the compression test right get you a timing cover like mentioned before or your asking for problems. Hope you replaced all timing components since you were there to prevent any timing mishaps, down the road.
GOT IT RUNNING but now I have a bad GM MAF translator. (got it wet when filling the coolant cap back up with water:ohdamn:
Solution
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
